3D custom rotation
Command
Path
Rotate 3D
Modify > Rotate
The precision of the rotation values that can be entered (degrees, minutes, and/or seconds) depends on the Units setting.
To rotate at custom angles in 3D:
Select the 3D object or objects to rotate.
Select the command.
The Rotate Object in 3D dialog box opens. Specify the rotation parameters.
Parameter
Description
Rotation Angle
Enter the angle of rotation
Center of Rotation
Specify the desired center of rotation:
Working Plane Center
Object Center
Next Mouse Click
Rotation Axis
Select whether the rotation axis will be based on the Active Layer Plane or the Working Plane, and whether to use the X, Y, or Z axis
Rotating objects
